Used Boat Buying Process
Old 09-01-2019 | 11:10 AM
Default Used Boat Buying Process
Newbie here wanting to know the best way to go about buying a used boat. I've found a minty 25 Outlaw that I'm going to see in a few days. It's a 1999 SST that is spotless with rebuild 61 hours ago. My plan is to go look at it and make an offer pending a survey and compression test. Not sure how to go about the compression test. I have tested compression on motorcycles before, I'm assuming the procedure is similar. What do you experienced boat buyers suggest? Finding a surveyor and then taking to a boat mechanic? Also, anything in particular I should look for in this boat? Standing by.
Tomok is offline
Old 09-01-2019 | 11:24 AM
If you’re going to have a survey done, that should include compression test
tdbrickndirt is offline
Old 09-01-2019 | 11:33 AM
I wasn't sure that was included in the survey. I will call a few surveyors.
Tomok is offline
Old 09-01-2019 | 11:40 AM
My surveyor had options up to and including mechanical engine testing, etc...
F14A water jet is offline
Old 09-01-2019 | 11:42 AM
Thumbs up
OK thanks. Researching surveyors and services now
Tomok is offline
Old 09-01-2019 | 12:05 PM
A lot of people have been burned using a surveyor. They did not pick up on a lot of issues. Do your due diligence!!
underpsi68 is offline
Old 09-01-2019 | 12:13 PM
RollWithIt's Avatar
Definitely do your homework on a good surveyor. I've found they can "miss" things.... Be sure to give the boat a very good examination, use a qualified surveyor and given it is a Baja, a quick check with a moisture meter is not a bad idea either.
RollWithIt is offline
Old 09-01-2019 | 12:16 PM
Will do.
Tomok is offline
Old 09-03-2019 | 04:57 PM
Def moisture meter & compression check and any receipts & maint records from boat owner are very helpfull
PartyBarge22 is offline
Old 09-03-2019 | 05:53 PM
Indy's Avatar
Member #154
Where are you located?
Indy is offline
