95' Formula 232LS bravo3 to bravo1 swap, NEED prop help! >
Old 09-04-2019 | 05:13 PM
Default 95' Formula 232LS bravo3 to bravo1 swap, NEED prop help!
So I just bought a bravo 1 lower to replace the old bravo 3 due to a failing carrier bearing and leaking shaft seal... But now I need to figure out what prop to go with for the new B1 lower unit...
My boat details:
1995 F-232 LS
Approx. 4300 lbs.
Merc 454 Mag (stock with through-hull)
Bravo 3 upper with 27/32 gears equating to 1.5 ratio with the B1 lower.
Boat has trim tabs that I never need to use.
Bravo 3 top speed was 55mph at about 4800 rpm
Would like to still have decent low end but more top speed... Maybe hit the 60's?
What prop size and pitch should I start with???
ridetheblue14 is offline
Old 09-04-2019 | 05:29 PM
Unless your lower is toast, it can be fixed. that said....
Your upper gears with a 1.5 are 32/27 and the lower are 15/19, which are the same as the B1 ratios
Going from a B3 to a B1 your going to get more slip. Being under 60+ mph you may even loose some speed. What ever pitch prop you were using, get the same pitch and find the largest diameter. Can also look at more blades (4 and 5) but this does give you more lift and that can bring its own problems or fixes
AllDodge is offline
Old 09-04-2019 | 05:56 PM
That ratio upper with the B 3 lower (16/27)should be a 2:1 ratio, what is the pitch on the B 3 set ?
JaayTeee is offline
Old 09-04-2019 | 06:31 PM
Ratios
AllDodge is offline
Old 09-04-2019 | 07:33 PM
I'll guess a REV 4 21 would get you real close to what you want or a Mirage Plus 21-23.
Good Luck
GLENAMY 242SS is offline
Old 09-05-2019 | 01:11 AM
I would start with a 23 Mirage Plus prop.
Griff is offline
Old 09-05-2019 | 07:14 AM
Trust me these smaller Formulas love the Rev 4 prop with the extra bow lift. Whatever pitch you use do yourself a favor and try a REV 4.
Old 09-09-2019 | 01:40 PM
it says 28p on the bravo3 set
also yes on the gears and ratios you mentioned... and I looked into fixing it (doing it myself and paying a shop) and the price was near the cost of a new B1 lower from SEI. I prefer the simplicity of a B1 lower and really don't think I need the B3 for a 23' boat... Also the ease of prop change as well with the B1
Old 09-09-2019 | 09:55 PM
28, I’d say 21mirage + or rev 4 also
JaayTeee is offline
