Mercruiser Module assembly ( knock sensor) >
Old 09-12-2019 | 12:52 PM
Default Mercruiser Module assembly ( knock sensor)
I have a 1997 formula with a 454 MPI and the knock sensor has failed . The part is no longer available through Mercury ( part # 805443T superseded by part # 805443) and I cannot find one. Does anyone happen to know if their is any way to cross-reference it to an aftermarket part or possibly know someone that might have one ?
Ken
BigKen is offline
Old 09-12-2019 | 02:58 PM
I saw this listed the other day for the new 540 4v Reman Mercury offers in the parts section:
Mercury-Mercruiser 840130A05 CONVERSION KIT Ignition
it looks like the same ignition my HP500 uses and they listed this as a conversion for the no longer used knock sensor mine has which is the same part number as yours. Might be worth a call to Mercury to see if it can be converted as the 540 reman appears to use the same thunder bolt V ignition.
Donzi1979 is offline
Old 09-12-2019 | 03:09 PM
articfriends's Avatar
Ken
I have 1 off a good running boat I converted to Mefi3 if your interested pm me, Smitty
articfriends is offline
Old 09-12-2019 | 03:15 PM
F-2 Speedy's Avatar
Good guy here, I dont have one so ya betta snag it up.
F-2 Speedy is offline
Old 09-12-2019 | 03:27 PM
Smitty,
I will take it . can you PM me with payment options ?
BigKen is offline
Old 09-14-2019 | 11:44 AM
What symptoms were you having that brought you to a failed knock sensor?
Keith
Tractionless is offline
