oil temp question >
oil temp question
oil temp question
Old 09-12-2019 | 07:28 PM
BBYSTWY's Avatar
Default oil temp question
So normally these threads go my oil temp is too high...mine is the opposite...my oil temp is not coming up like I believe it should
460 with dart heads 8-71 blower
Idling around the gauge which starts at 140 does not move at all...after running pretty hard for a few mins the needle moves up to right at 140
Sending unit is located above the stock oil filter pad in the normal hole right there...I have the stock merc oil filter relocator and stock oil cooler that came on the motor...it started life as a 525sc merc motor
I'm thinking maybe the thermostat in the relocator housing is stuck open but not sure if that actually happens or not or if I should be looking somewhere else??
thanks
BBYSTWY is offline
Old 09-12-2019 | 08:18 PM
It’s easy enough to check, remove it from the housing, throw it into a pan of boiling water and see if the rod end extends, it should, and after you remove it and it cools down, it should retract
JaayTeee is offline
Old 09-12-2019 | 08:23 PM
BBYSTWY's Avatar
Yea that's a good idea...may just replace it if I pull it...at least have one on hand incase it is bad...sh!tty part is I have to either pull the port tailpipe or unbolt the housing to get to the thermostat lol
BBYSTWY is offline
Old 09-12-2019 | 08:45 PM
Lift the hatch after a run and put your hand on the filter. You will know right away if it’s 140 or 240.
ph1971 is offline
Old 09-12-2019 | 09:02 PM
BBYSTWY's Avatar
I've been running it with the hatch off as I plan to get a new interior made this winter....that being said it is 140 not 240 lol
I did swap the water temp and oil temp sending units to make sure that wasn't the issue and both gauges with either sending unit read the exact same so I know everything is good just not sure if its an over cooling issue or if the thermostat could be stuck or what?? Not sure if these have been known to stick or if my problem is elsewhere...that is a good idea to pull it and check it so I'll probably start there and see what I have I suppose...
BBYSTWY is offline
Old 09-12-2019 | 10:19 PM
Rookie's Avatar
If I recall the oil temp gauges start at 140°F. So it could be cold and read just below the 140°F mark. That location I believe is cooled oil returning from cooler. So it appears the cooler is doing its job. If you want to know how hot you oil is getting you need to change the sender location to oil that is not cooled. I personally like to know the temp of the oil that is going to my main and rod bearings not the temperature of the pan oil.
Rookie is offline
Old 09-12-2019 | 10:26 PM
BBYSTWY's Avatar
I agree with that but shouldn't it still be heating up to over the 140 mark? The oil filter housing to my knowledge has the internal thermostat that should bypass the cooler until the oil is up to temp...that being said I was expecting to see it come up to 200 or whatever the thermostat temp rating is then drop when it opens...maybe I'm wrong on that but I assumed it would work just like a water thermostat in that I should be to see it drop when the thermostat opens??
BBYSTWY is offline
Old 09-12-2019 | 10:46 PM
Rookie's Avatar
My oil temp on my cooled oil barely ever goes over 145°F. If you touch the uncooled delivery hose it's warmer. I also run 168°F oil thermostats.
Get one of these and shoot the pan. Handy and you'll use it more than you think.
https://www.harborfreight.com/121-in..._q=thermometer
Rookie is offline
Old 09-12-2019 | 10:49 PM
BBYSTWY's Avatar
Oh yea I have a couple of those lol...so knowing where my sender is you think that's the "cooled oil" and maybe everything is fine? Just thought it had to heat up to burn off condensation and honestly I was expecting it to go the other way and have to add a bigger cooler...is the merc cooler really that efficient?
Thanks for the replies!!
BBYSTWY is offline
Old 09-13-2019 | 05:40 AM
Mbam's Avatar
Offshoreonly Advertiser
Shoot the cooler itself. The oil runs through the shell so If it is cold and the filter is hot it means the oil is bypassing the cooler.
Shoot the pan - if the pan is hot and both the cooler & filter are cold it means the oil is bypassing entirely. Won't be the first time someone left the bypass valve out of the oil adapter or the block or used the wrong valve (too low pressure).
After running hard 200-250 plus in the pan is expected
Mbam is offline
