Beginner question on 377 v 496 >
Old 09-16-2019 | 09:28 AM
Default Beginner question on 377 v 496
Have a regular 377 in a 247 islander weighs 4,000lbs. The reg 496 weighs 400 more lbs and offers a .7 better power to weight ratio. Is that worth the extra weight? How big a difference in top speed/boat performance does .7 make. Again, new to this, please just helpful advice.
ericmartinez1 is offline
Old 09-16-2019 | 10:19 AM
I'm not sure where you got the 400 lb weight difference. I think it's closer to 100-150 lbs. regardless, I believe too many people over think the weight issue and under think the torque advantage of the big block. It will generally make more torque at a given rpm compared to the small block. I love small blocks but the big block will almost always have an advantage in the marine environment.
Trash is offline
Old 09-16-2019 | 10:37 AM
I googled both engines to get their weight. Thank You for your response. I bought this boat, and thought it would top out higher, Im maxing out at 45 mph with a full 80 gallons of fuel. A guy I know to me it was “A Lot of Boat for that motor” insinuating performace is not optimal. Just wanted some insight.
Old 09-16-2019 | 10:53 AM
Islanders are super bow heavy compared to the cuddy models, so extra weight in the stern actually helps balance it out. Do you have the Bravo or Alpha drive?
Baja Rooster is offline
Old 09-16-2019 | 01:37 PM
Bravo Drive
Old 09-16-2019 | 01:55 PM
I’d put in the bbc without a second thought. If you’re in fresh water find one with aluminum heads, manifold and exhaust and you’ll be pretty darn close to a sbc.
I swapped out a lot of cast iron for aluminum on my 272 Islander with the 502 and still looking for a prop with enough bow lift to compensate for the weight loss.
Old 09-17-2019 | 01:29 AM
BoatTest.com shows it runs 60mph with a 375hp 496mag.
Even with your 320hp, you should still be running around 55mph, so something is not right.
Griff is offline
Old 09-17-2019 | 07:01 AM
Doing a quick google check sbc is 575 and bbc 685....
and there is no substituent for cubic inches accept for cubic dollars
the bbc is already one step above a sbc to start with....
flashgordon is offline
Old 09-17-2019 | 07:28 AM
Talking
Originally Posted by flashgordon
and there is no substituent for cubic inches accept BOOST
I fixed it for you
underpsi68 is offline
Old 09-17-2019 | 08:21 AM
[QUOTE=flashgordon;4706720]Doing a quick google check sbc is 575 and bbc 685....
the bbc is already one step above a sbc to start with....[/QUOTE
You are absolutely correct, something isn’t right! That is what has made me start thinking engine swap. As I’ve had it out, first I got an emission fault and engine went into guardian mode. O2 sensor was fouled. Replaced it, took it back out, got a Fuel System Fault and engine went into Guardian mode. Its currently in the shop again.
