496 raw water pump >
496 raw water pump
496 raw water pump
Old 09-18-2019 | 07:25 AM
Default 496 raw water pump
ISO 496ho raw water pump, mine is leaking from the seal behind pulley, thought I would look here before I go new
chartersj is offline
Old 09-18-2019 | 07:31 AM
Don't know your serial number.
Even if you can find a used one, just rebuild the one you have. The seals and bearings should be easy enough to find
https://www.mercruiserparts.com/bam/...31815/6708/210
AllDodge is offline
Old 09-19-2019 | 06:31 AM
Yeah that's a good idea. And that way I could have a spare as well if I do find another
Old 09-19-2019 | 06:33 AM
Get the stainless Hardin pump and don't look back. It is pricey but well worth it.
underpsi68 is offline
Old 09-19-2019 | 06:37 AM
Yeah I have read that's the best option. My pump has scoring in the brass so I already have the ss washers on either side of the impeller
