Oil blowing out of engine
Old 09-27-2019 | 10:41 PM
Default Oil blowing out of engine
Oil is coming out on the port side near the rear of my 496. Oil lines going from pump to filter I think. Any suggestions?
bms26 is offline
Old 09-28-2019 | 07:13 AM
The oil pressure sensor, oil cooler or one of the lines
AllDodge is offline
Old 09-28-2019 | 08:32 AM
Wobble's Avatar
SORE MEMBER
missing oil gallery plug
Wobble is offline
Old 09-28-2019 | 10:54 AM
Tinkerer's Avatar
A picture is worth a 1000 words.
Tinkerer is offline
Old 09-28-2019 | 12:33 PM
Follow the leaking oil to the leak?
underpsi68 is offline
Old 09-28-2019 | 09:23 PM
I can’t tell hence the question smart ass
bms26 is offline
Old 09-28-2019 | 09:37 PM
BUP
As I mention many times up here --- ENGINE SERIAL number is needed. There is a service bulletin about oil leaking and oil line replacement in which could be the issue. It possible can be a good idea to take your boat into a oem dealer and have it looked over and see if the service bulletin is in fact per your engine and the issue at hand.
IMO in a lot cases with stock oem apps it might be a better avenue for one to seek out an OEM dealer instead of guess work to have all looked at and possible any outstanding recalls and service bulletins that possible can be attached to your engine and outdrive .
BUP is offline
Old 09-30-2019 | 08:10 AM
You can put some dye in the oil and look at the engine under a black light (iPhone LED flashlight works too). Much easier than guessing where it's coming from. NAPA has it.
ALL_IN! is offline
Old 09-30-2019 | 09:05 AM
Sydwayz's Avatar
Forum Regulator
On one of my former 496HOs, I had a leak where the dipstick enters the oil pan. There is a putty or similar that seals it. I had a marina address it, and it was a simple fix.
Sydwayz is offline
