Go Back  Offshoreonly.com > Technical > Detailing, Painting, & Fiberglass
Lightweight engine Hatch. Nidacore, Carbon core, or ???? >
Old 09-30-2019 | 01:11 AM
Talking Lightweight engine Hatch. Nidacore, Carbon core, or ????
I am making a new hatch for my Scarab 33 AVS and want to lose weight. The old one is about 150 lbs. I do not need foam I just want to walk on it, and have it LIGHT weight. I was going to go coosa but I think there are ligther materials . Any thoughts.
cyrus77 is offline
Old 09-30-2019 | 09:52 AM
BBYSTWY's Avatar
Following
BBYSTWY is offline
Old 09-30-2019 | 10:38 AM
I build all my Parasail boat flight decks, hatches, floors, ect using Nida Core or equivalent. When done properly, it's solid as concrete and extremely lighweight. Good luck.
PARASAIL941 is offline
Old 10-01-2019 | 08:10 PM
Ok looks like I am using Nida core 1" with glass and bracing ribs.
cyrus77 is offline
Old 10-01-2019 | 08:33 PM
Is the hatch flat or slightly crowned?
Old 10-01-2019 | 11:35 PM
scippy's Avatar
Forgive for jumping in, but let's just say it's slightly crowned then what?
scippy is offline
Old 10-02-2019 | 05:23 AM
cougarman's Avatar
Subscribed ...
cougarman is offline
Old 10-02-2019 | 06:44 AM
BBYSTWY's Avatar
I'd be very curious to see the process of using the nidacore if you don't mind showing that? Also could it be used for structural things like seats and such? I need to rebuild my backseat and hatch this winter to accommodate my new motor and I never knew this stuff existed until you started this thread so some progress/process pics would be awesome!!
Thanks in advance for any help!!
BBYSTWY is offline
Old 10-02-2019 | 07:26 AM
Same materials , just was going to discuss easy methods to build either style hatch.
Old 10-02-2019 | 01:44 PM
madbouyz's Avatar
Whatever they call themselves any modern composite foam core will suffice . The only REAL weight saving comes from not using a wood coring material. You can pick up a 4'x6' sheet of foam core easily with one hand but try it with the same sized piece of plywood .
The fact is you're still going to use very similar amounts of glass and resin in the construction especially when you factor in the required support crossmembers .
I've done an engine hatch using balsa core and gas tank and lazarette hatches using foam cores and I can say that balsa does start out very light but it can absorb a lot of resin in the process. Not quite as much though for the foams .
Also , with foam cores you have to be a little more mindful of through bolting hardware .
madbouyz is offline
