Mercruiser 6.2L MPI low oil pressure
Hello, and thank you for the opportunity to share my low oil pressure problem on a Mercruiser 6.2L MPI MIE engine. Your opinion on a solution would be greatly appreciated.
My starboard engine has low oil pressure issue. Upon starting it reads low 20's (port engine is double that), If I put the engine under a load it will increase to upper 20s, maybe 30 for a while, then drop slowly. At 4,000+ rpms, it takes no time for the smartcraft alarm to sound. If I keep it around 3,500 rpm, it will run for some time, but eventually lose pressure also. If I pull back to idle, it may read 10 psi or less, then slowly increase again to 20 or so. I have switched the oil pressure sending units and still same results. Any ideas of a possible simple solution to try since not close to qualified mechanic and do not have trailer of my own. I would need to have someone tow for me.
The engine sounds good, no knocking noises. Would you recommend switching the oil sensors?
Engine Model: 3-0620220T
H.P.: 320
Serial #: OW390580
H.P.: 320
Serial #: OW390580
https://www.mercruiserparts.com/bam/...31957/11681/40
Remove the larger sensor and install a mechanical gauge. Might be able to get a loaner tool from a local parts place
There are 2 oil pressure sensors, one used by a gauge and one used by the PCM. The one used by smartcraft would be the smaller of the 2 (item 36). Which one was switch?
Thanks for the advice. I previously switched the sending unit (item #38) and may not have a chance to switch the pressure sensor (item #36) this weekend, but will do so as soon as possible and post what I find.
Just to clarify the digital reading matches the analog gauge at the helm.
Thank you
Thank you
H.P.: 320
Serial #: OW390580
H.P.: 320
Serial #: OW390580
Yes, it was the pressure sensor (not the pressure sending unit). The pressure sending unit screws into the pressure sensor, which is attached to the engine. So, I had to remove the sending unit from the pressure sensor before I could remove the pressure sensor from the engine.
