Changing trailer brakes from drums to disc. >
Old 11-05-2002 | 11:26 AM
tanned fat looks better's Avatar
Default Changing trailer brakes from drums to disc.
Anyone do this? What kind of cost is involved? I need new brakes and i'm thinking about switching to disk. Is it worth the expense or touble?
tanned fat looks better is offline
Old 11-05-2002 | 11:40 AM
Crazyhorse's Avatar
Dyno and Traviss have both expressd interest in this swap. You might want to give them a holler.
Crazyhorse is offline
Old 11-05-2002 | 11:44 AM
Dave M's Avatar
Veteran: Navy
I replaced my drum with drum again and wish I would of did the disk conversion. After one season my brakes are acting up again. The price is similar. I was just weary of those "bolt on conversions". It seem like you always run into some snag.
Dave M.
Dave M is offline
Old 11-05-2002 | 11:48 AM
dyno's Avatar
Charter Member #655
seams like a good idea to me but I cant find any 6 lug kits
If your boat has a sail do you ride a horse to the ramp?
dyno is offline
Old 11-05-2002 | 11:50 AM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
I am going to do the same thing. I have one axle on my tandem trailer with drum brakes, and I am going to all for discs. Brian, TOPDJ; did this on his with the Tiedown Engineering kit, and said it was easy. Do a search for his post.
I spoke w/ my trailer manufacturer, and he does not like the Tiedown system. I am having both of my axles replaced, and I think he is going to supply disc brakes on the new axles for me. I can also get them locally at a campler place for $145 each wheel. Champion trailer parts (on the web) has them for about $100 each wheel. I was also told I need to change out the plunger/actuator in the surge controller to go from drum to disk brakes. I am learning as I go, but hope to have it all done in 2 weeks or less.
Sydwayz is offline
Old 11-05-2002 | 11:51 AM
PhantomChaos's Avatar
I just reworked my brake system a few weeks ago. I have the electric over hydraulic six-disk system. I had the rotors turned, but I still had a “pulsing” when using the brakes like they were warped. Anyway, I took the chance to make a change and replaced the rotors, calipers and everything to stainless steel. A little pricey, but I think I will save in the long run. So if you’re upgrading to disk, and you dump in the salt, consider going stainless.
PhantomChaos is offline
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
www.championtrailers.com has everything you need.
Also try Mr. Offshore from here on OSO. He sells trailers and parts!
Sydwayz is offline
Old 11-05-2002 | 12:01 PM
Cool
I'm going to do it as soon as I can get the boat off the trailer. But I need advise if I should do two or all three axles. Will probably use Xtreme in Riverside as they do great work and have recently received a lot of very positive publicity.
burtandnancy is offline
Old 11-05-2002 | 01:04 PM
Flashwave's Avatar
Trailrite replaced mine using Demco parts with a 2 year warranty. Cost was about $1600 for 2 axles. Well worth the money. You can buy cheaper parts, but, I'm told they won't last.
Flashwave is offline
Old 11-05-2002 | 01:23 PM
olemissalum's Avatar
I did my trailer and it was easy. Northern Tools sells a kit made my TIE DOWN, about 120 per wheel and I highly recommend them. Installation a breeze and work great. I hate Drums
olemissalum is offline
