ISO Pair of 540 cu/in or larger Can need gone through >
Old 10-15-2019 | 10:16 AM
Default ISO Pair of 540 cu/in or larger Can need gone through
I'm trying to save a few dollars so I am in hopes of finding a pair of decent built 540's or better cu/in wise. Can need gone through but no catastrophic failures please. I intend on changing a few things regardless of what you have anyway so send price and pics if you have something.
I have a budget so please don't try to sell me $50,000 in engines. TIA
Baja226sport is offline
Old 10-15-2019 | 11:07 AM
Sick Stinger's Avatar
Brotherhood #1
I have some 540s
688 Donovan’s also
or some aluminum 510 super cat darts
Sick Stinger is offline
Old 10-15-2019 | 01:11 PM
Originally Posted by Sick Stinger
I have some 540s
688 Donovan’s also
Info on engines? Pics, prices? Are these ready to run or need work or what? Where are you located?
88sport240 is offline
Old 10-15-2019 | 07:36 PM
pair of 572's they run aprox 30 hrs run with no leaks or issues whats your budjet?
pair of 540's with 256 blowers 6 hrs on them, no issues or problems
dont respond on thread ..... PM
Located in michigan
welfare racing is offline
Old 10-15-2019 | 09:00 PM
Brotherhood #1
88 Sport
540s has whipples, sold whipples and put intakes and carbs in them.
hours metered read 58 on boat.
merlin blocks and heads. Eagle lower ends , roller valve train. Dart intakes
, Dom carbs. MSD Ign setup. 12 qts base pans.
12500
The 688s are Donavan base motors. All parts are top for the line.
EDM Rods , Billet cranks, 14 qts base pans dart 360 heads or brodex BBX5 CNC heads. Shaft rockers , oil squirter valve covers ect. 1 motor ready to assembly long block other needs machine and matching set of pistons purchased.
ready to assemble 18k other is 16k
Old 10-15-2019 | 09:04 PM
Brotherhood #1
The 510 are supercat aluminum dart blocks. Everything is also top end.
dry sump base, EDM Rods, crank oil squirters, rocker squirters in V covers, Billet cranks. Shaft rockers, dart 360 heads,
need refresh. Motors are apart ready for rebuild. Long block motors, 12k each.
can have any motors built and dyno’d.
Old 10-16-2019 | 07:36 AM
Located in michigan
Buy with confidence from these guys
PartyBarge22 is offline
Old 10-25-2019 | 11:18 AM
Have two 540CI complete that need rebuild 15000.00
Ron 504-616-6005
Sporl Performance is offline
