Cam gear for thunderbolt on a 500 EFI cam >
Old 10-15-2019 | 12:24 PM
Default Cam gear for thunderbolt on a 500 EFI cam
I am running cams out of 500EFIs and using thunderbolt distributors that I think came off of mid 90s 350s, I need to know if I need to swap my distributor gear for a bronze gear? I have read that they used crane cams in the blue engines and a steel gear was ok but I do not want to find out the hard way. I would appreciate any info. Thanks
regalman4925 is offline
Old 10-15-2019 | 12:37 PM
SB
Crane cams that part #'s end in IG have iron gears.
SB is offline
Old 10-15-2019 | 12:40 PM
F-2 Speedy's Avatar
stock dist gear on a 500 efi is iron, at least all the ones Ive seen
F-2 Speedy is offline
Old 10-16-2019 | 08:57 AM
i would give crane cams a call but i use a melonized gear with crane hyd roller cams.
mike tkach is offline
Old 10-17-2019 | 06:09 PM
BUP
bingo
BUP is offline
Old 11-18-2019 | 09:27 PM
Rookie's Avatar
I'm building some 454's with 500EFI cams and for $33/melonized gear it's worth the piece of mind changing it.
Is the thunderbolt distributor 0.491" or 0.500"?
Rookie is offline
Old 11-19-2019 | 01:51 AM
I ran the stock TB IV dist gear with a Crane 731 with no problem for 150+ hrs(sold boat), but that was like 15 years ago.
Griff is offline
Old 11-19-2019 | 05:34 AM
every one i have seen was .491.
