Mercury Marine VesselView Mobile >
Old 10-22-2019 | 02:16 PM
DiamondPerformance's Avatar
Offshoreonly Advertiser
Default Mercury Marine VesselView Mobile
Anyone using this ?Mercury Marine VesselView Mobile - Connected Boat Engine System for iOS and Android Devices
https://www.amazon.com/Mercury-Marine-VesselView-Mobile-Connected/dp/B01MTGBKPQ/ref=b2b_gw_d_simh_1/138-6975834-7541129?_encoding=UTF8&pd_rd_i=B01MTGBKPQ&pd_rd_r=a2b15bf3-fe76-45d4-880a-dbf467acb901&pd_rd_w=hvD7I&pd_rd_wg=n4F1D&pf_rd_p=61599782-672e-4e85-babb-27736eff5e78&pf_rd_r=6TQA9JV2NK9SYVD29RB1&psc=1&refRID=1RPA60E37D1YG2QV7YQ3 https://www.amazon.com/Mercury-Marine-VesselView-Mobile-Connected/dp/B01MTGBKPQ/ref=b2b_gw_d_simh_1/138-6975834-7541129?_encoding=UTF8&pd_rd_i=B01MTGBKPQ&pd_rd_r=a2b15bf3-fe76-45d4-880a-dbf467acb901&pd_rd_w=hvD7I&pd_rd_wg=n4F1D&pf_rd_p=61599782-672e-4e85-babb-27736eff5e78&pf_rd_r=6TQA9JV2NK9SYVD29RB1&psc=1&refRID=1RPA60E37D1YG2QV7YQ3
www.diamondperformanceparts.com
[email protected]
http://www.facebook.com/pages/Diamon...07878772615803
302-521-0123
The Best Parts & Service At The Best Price
DiamondPerformance is offline
Old 10-23-2019 | 05:10 AM
Yes, and it works pretty well. When I repowered, I didn’t want to cut up the dash for an SC1000 so I went this route. My analog gauges still work, and the VVM provides redundancy and more accuracy (engine temp, fuel economy, engine hrs, etc). The unit will mount under the cowl and provide decent connectivity, but I suggest getting it closer to the phone/driver to prevent having to reconnect repeatedly.
Speedracer29 is offline
Old 10-23-2019 | 03:19 PM
Where does it connect?
[email protected]
302-521-0123
Old 10-23-2019 | 03:58 PM
The module plugs into the SmartCraft port on the PCM. Load the app on the smartphone or tablet and it connects to the module via Bluetooth.
Old 10-23-2019 | 05:49 PM
Ok thanks, I'll look for it on the top of the 496.
[email protected]
302-521-0123
Old 10-23-2019 | 07:21 PM
would this work w/ an mefi4b ecu?
sutphen 30 is offline
Old 10-23-2019 | 07:31 PM
I don’t have an answer, but the info above is what I found.
Old 10-25-2019 | 01:26 PM
Anyone use it on a twin engine setup ? Am I better off buying two separate vessel view units or building a smartcraft network and running one ?
Would it combine gallons used for both engines if they WERE on the same network and one vessel view unit ?
Thanks!
Doug
Boatally Insane is offline
