Go Back  Offshoreonly.com > Owners Forum > Excalibur
Different riser temperature >
Old 10-25-2019 | 02:01 AM
Default Different riser temperature
Hello everybody!
I have a Merc 502 on my 26 and I realised that the two risers have different temperature.
The part circuit are new but the right one is quite hot (I cant't leave the hand more than 5 seconds), the left one is close to be cold.
Water flush out the exaust seems good from both sides.
Of course right side has a little bit more water steam...
Is this normal???
Thank you very much
Masfel is offline
Old 10-25-2019 | 05:46 AM
If you can't leave you hand on it it is to hot. Start checking for a restriction in the lines/coolers.
underpsi68 is offline
Old 10-25-2019 | 07:08 AM
The 2 will always be different, how much different can be an issue. Use a IR temp gun and measure the difference
AllDodge is offline
Old 10-25-2019 | 11:53 AM
You might want to verify proper gaskets were used at riser joint. They may have 2 or 4 water passages. Good luck!
PARASAIL941 is offline
Old 10-25-2019 | 12:20 PM
GLENAMY 242SS is offline
Old 10-25-2019 | 02:02 PM
Need more info. Year. OEM manifolds or aftermarket? T-stat and impeller changed? All hoses and coolers flushed. As stated, have manifolds/risers been been checked.
shunter2005 is offline
Old 10-25-2019 | 02:20 PM
I have noticed this before but never completely figured out why. Why is it AD?
liberator221 is offline
Old 10-25-2019 | 02:42 PM
Fluid dynamics, water flows the path of least resistance. So what flows thru one side because its easier and once there is enough resistance from the flow on one side the other side flows. As flow increases it will always have more on one side then the other.
Water comes up from the pump, thru the hose and can for the most part go straight across and out one side of the exhaust, the other side the water has to do a 180 to go out
Only way to get 100 % equal is both sides have to be 100% full
AllDodge is offline
Old 10-25-2019 | 02:50 PM
Yours should be like this I think
AllDodge is offline
