Pro charger 350 Mag Mpi >
Old 11-03-2019 | 04:13 PM
Default Pro charger 350 Mag Mpi
ProCharger Marine Kit for 1999-2002 Mercruiser 350 Mag MPI ,$2500 plus shipping.New hoses,belt and oil included. You may need an alternator relocation bracket on some models.
Donzi Z22 is offline
Old 11-04-2019 | 08:37 PM
Includes shipping ?
Old 11-06-2019 | 05:18 PM
Did you run this setup? If so what numbers were you seeing?
I have a '00 22ZX with the 350 Mag/Bravo1...might be interested.
_therealmattyice is offline
Old 11-06-2019 | 07:07 PM
I did not run it, with your hull you should gain 15 - 17 mph .
https://www.cpperformance.com/p-1242...0-mag-mpi.aspx
Old 11-08-2019 | 04:53 PM
Bump
Old 11-11-2019 | 04:44 PM
Bump
Old 11-30-2019 | 12:49 AM
Ttt
Old 11-30-2019 | 06:39 AM
Anyone successfully use this on a newer model? Really narrow window. I’m assuming that the ecm is the issue.
Alwhite00 is offline
Old 11-30-2019 | 10:03 AM
Any boat needs to have the ECU reprogrammed by Arizona Speed and Marine for $295 ,to take advantage of the pro charger.
ASM does this every day.
Also the one bar map sensor needs to be replaced with a two bar map sensor to read the updated ECU like a factor super charged engine has.
The kit from Pro Charger comes with a fuel regulator that increases fuel as needed by pulling vacuum from intake manifold.
The kit is set up for a stock engine and produces 5 psi.Boost is linear and goes up the harder you push on the gas.
You are not in boost all the time only when needed...
My GT500 has a max boost of 14 psi,but stays at 1 to 2,unless I get into it .
My Donzi has an Alpha Gen II and I'm afraid that I may blow it if I put this on.If Its doesn't sell,I'll put it on and see if the drive can handle the power,if not then I will need a Bravo one Drive !
Old 11-30-2019 | 02:09 PM
I have a 2011 mpi, nobody has a kit. Just wondering if anyone has put one on a newer engine.
