Can help
I’m refreshing a 1995 502 efi mag
it needs a cam as it was starting to eat a lobe
im up grading the flat tappet for a hydraulic roller
and may go roller rockers as well
without getting the factory Merc eci re programmed I would like a cam recommendation
boat has the factory captains call exhaust and manifolds
don’t want to change the exhaust either
any help or suggestions appreciated
I'm pulling mine next month to install a more aggressive cam so I could supply:
Cam - roller stock 200 hrs, springs from same, Rockers Comp Extreme new (less than an hour),
Let me know if any of this works for you.
Originally Posted by [email protected]
Can you give me some specs on the cam?
If you go with roller rockers, highly recommended, I have a set of new Comp Cam extreme for sale $ 300
ROLLER TAPPET CAMSHAFTENGINE MODEL
7.4L
454 MAGNUM
502 MAGNUM
8.2L
Lobe Lift + .020 (0.051)
Exhaust
.284 (7.214)
.342 (8.687)
Intake
.282 (7.163)
.342 (8.687)
Duration at .050 In. (1.27 mm)
Cam Lift
Exhaust
209°
227°
Intake
209°
211°
Journal Diameter
1.94282-1.9492 (49.485-49.509)
Journal Out Of Round
.001 (0.025) Maximum
Camshaft Runout
.002 (0.051) Maximum
Timing Chain Deflection
.375 (9.5) from taut position [total .75 (19)]
I’m interested in the rockers and cam
i need to talk to my builder, I’m out of town for the next week and a half and won’t see him until late next week
what valve cover did you use with the rockers?
and how much for the cam
