Cam help for a 502 >
Cam help for a 502
Cam help for a 502
Old 11-14-2019 | 03:41 PM
Default Cam help for a 502
Hi all
from what I can find mercrusier used gm part #12551622
for the stock 415 HP motors
i found gm part #24502611 has sed in the 450 hp motors
has anyone used this in their efi mercrusier motor?
Davebleil58@gmail.com is offline
Old 11-15-2019 | 06:39 AM
articfriends's Avatar
I have one, PM me
articfriends is offline
Old 11-15-2019 | 09:20 AM
Smitty, can you install a GEN VI step nose cam into a MARK 4 block?
Thank you.
GLENAMY 242SS is offline
Old 11-15-2019 | 09:44 AM
Thank you.
the answer is yes,just use a timing chain for a gen 6 engine.
mike tkach is offline
Old 11-15-2019 | 11:41 AM
Old 11-15-2019 | 11:48 AM
I found a Dennis More out of La sells tons of marine parts on EBay and has 100% positive feedback
he sells a custom ground cam for a gen 5 with the specs I think I’m looking for
he says no reversion and no ecm programming needed
this is the eBay item number if interested 312163846855
Old 11-15-2019 | 11:54 AM
Does it, Cam, have a Mechanical fuel pump lobe? or you will need an electric pump on MARK 4 with relay and return setup.
Old 11-15-2019 | 11:58 AM
110 LSA. Anybody have thoughts on this?
Old 11-15-2019 | 12:32 PM
My thought is I wouldn't run anything less than 114 with stock exhaust
Griff is offline
Old 11-15-2019 | 12:34 PM
My fuel pump runs off the sea pump
it doesn’t matter for my motor
