Aluminum heads >
Aluminum heads
Aluminum heads
Old 11-24-2019 | 08:32 AM
Default Aluminum heads
Is it general rule not to use aluminum heads on raw water cooled engines? It seams there are some who have no trouble and some do. I don’t boat in salt water so that’s not a concern. Thanks
27formula is offline
Old 11-24-2019 | 08:43 AM
their are tons of fresh water boats with aluminum heads.also many closed cooling boats with aluminum heads,merc 525 being one example.
mike tkach is offline
Old 11-24-2019 | 09:06 AM
Ok I read lots of conflicting post about it and figured this be a good place to ask. Thanks
Old 11-24-2019 | 10:01 AM
GPM
Aluminum heads can be anodized for marine application.
GPM is offline
Old 11-24-2019 | 01:46 PM
Ran 1992 AFR heads till sold engine in 2014. Freshwater cooled. Water passages had some corrosion but lots of life left.
Saltwater use is another story........
Ryan00TJ is offline
Old 11-24-2019 | 11:41 PM
BUP
It depends on the lake water - mineral deposits - ph balance - brackish water and so on. In my area we have one lake that just causes havoc with t stat housings - T stats - water circ pumps and when you drain the blocks heavy rusted color water drains out.
Also it corrodes the box frames on the trailers pretty bad as well. Fresh water hose flushing can help for open / raw water cooling engines. We have a lot of mineral deposits as well that causes cooling issues. Especially the water passage in the transom assembly bell housing
BUP is offline
Old 11-24-2019 | 11:47 PM
BUP
Just example of the of the many --- A 2009 Volvo penta 496 MPI one owner and I have worked on the boat since Brand new from day one.. LOCAL LAKES only usage. Engine ran too cold and was in guardian mode because the coolant temp never reached higher than 135 degrees and it ran rich. I had to change the spark plugs as well The boat / engine only had 168 hours. NON closed cooled Volvo had the 496 s both ways - closed cooled apps and NON. Pic below. It had a stuck open T stat from all the corrosion.
BUP is offline
Old 11-25-2019 | 12:22 AM
BUP
BUP is offline
Old 11-25-2019 | 02:13 AM
Craney's Avatar
It also depends on the grade of aluminum they use.AFR heads are a lot heavier then the cheaper heads from China.
Craney is offline
Old 11-25-2019 | 06:08 AM
i think my motors have had bow tie heads 14044861, since early 90's ..is fresh water boat, last year i made it a closed coolant system.
flashgordon is offline
