502 build , cam, heads questions. >
Old 12-03-2019 | 02:43 PM
fastlane40's Avatar
Default 502 build , cam, heads questions.
Gen VI 502's.4.250 stroke,6.385 rods.No overbore.Compression around 9.3:1
What head CC's 320?I do have 2 sets of factory ported 088 500EFI heads or is any Aluminium head better than the 088?
What HP difference will I see using a 500 731 cam over the 741 525 cam?
If I do use the 731 am I able to use the net lash non adjustable valve train on a gen VI?
fastlane40 is offline
Old 12-03-2019 | 03:38 PM
F-2 Speedy's Avatar
your 1 step from a 540.........what are you using for fuel supply
F-2 Speedy is offline
Old 12-03-2019 | 04:53 PM
I did the 731 cam with AFR heads and Victor Jr intake 585 hp/611 tq @ 5200, also added the Holley snipper.
Texascuda is offline
Old 12-03-2019 | 11:13 PM
i have built several with the 741 cam and engine quest 320 heads,600 hp all day long.
mike tkach is offline
Old 12-04-2019 | 12:49 AM
You cannot use the non adjustable valve train for anything except the stock magnum cam.
You need rocker arm conversion studs and roller rocker arms for either cam.
Griff is offline
Old 12-04-2019 | 01:48 AM
fastlane40's Avatar
Yes about 8 cubes,
Fuel,Carb 950 I reckon.Aeromotive pumps.
So go straight for a 741 Crane?
Longer travel lifter and roller rockers.
Old 12-04-2019 | 12:54 PM
My 540's I went with the 731 cam and made 615hp/689tq. Dart pro 1 325cc heads, dart intake and quick fuel 1050 carb. Definitely on the small side for a 540 but behaves very well and pulls strong up to 5500 rpm.
GlennRotman is offline
Old 12-04-2019 | 01:16 PM
fastlane40's Avatar
Would there be any reason to go with the 731 instead of the 741?
Or is there HP to be gained.
Old 12-04-2019 | 01:26 PM
The 741 will definitely make more power than the 731 and is a better choice.
Griff is offline
Old 12-04-2019 | 02:01 PM
F-2 Speedy's Avatar
As stated above Id run the the 741 cam and the EQ heads as Mike said if running in salt, if you're running in freash water might look at the AFR 305 or the Brodix line up
