Dominator Carb Hats wanted >
Old 12-07-2019 | 01:05 PM
Default Dominator Carb Hats wanted
Anyone have a pair of Carb Hats that work with Dominator 1050 carbs lying around?
Thanks!
Swamplizard is offline
Old 12-08-2019 | 09:15 AM
I assume anything that can handle 5 1/2 inch carb opening will work?
Old 12-09-2019 | 10:12 AM
SB
Cover ? These are the cheapest I found doing a quick search. No reviews, so who knws if they seal well or not.
https://www.jegs.com/i/JEGS/555/15222/10002/-1
SB is offline
Old 12-09-2019 | 10:36 AM
BUP
I have the same covers and the summit ones - if you use a round carb gasket the thicker style that helps sealing.
BUP is offline
Old 12-09-2019 | 02:33 PM
Originally Posted by BUP
I have the same covers and the summit ones - if you use a round carb gasket the thicker style they help sealing.
Sorry I was unclear - thought that was what they were called .... looking for the things that replace the spark arrestor if you are pulling air in from outside the engine bay (like what they use with prochargers).
Old 12-11-2019 | 01:14 PM
I have a used one I'll sell for $200... (sorry don't have a pic of it in front of me, but here's a "stock" picture)
specs are here.....
https://www.superiorairflow.com/carb...der-blade.html
Boatally Insane is offline
