232 Islander "hook" in lifting strakes?
The outboard lifting strakes that continue to the transom feature a "hook" design feature where the last 6" or so are angled down some. Is this common across all Baja models? Is it a desirable hull design feature?
They must be under a stringer so could they be cut on 3 sides and folded up flat, then reglassed from the outside?
I believe they are called wedges. Depending on the manufacture/hull, some have filled them in and regretted it and others have seen positive results. I've seen them on everything from Formulas to Crownlines.
Hooks were put in lower performance models to help the less savvy pilots out, so any joe blow can jump in and run it. I once heard that some manufacturers put the hook in for liability/insurance purposes but I have no way to validate it.
They’re all different but on the outer strakes it helps the boat plane easier and stay on plane at lower speeds.
Both good.
I wouldn’t touch them.
And no, typically they are not under stringers. Normally they are filled w/filler then covered w/glass.
When you see people removing hook/wedges/tapers it’s almost always on the inner strakes or flat pad on center of hull.
Your outer strakes are out of water at speed and these are not and keeps the bow down and may be preventing that annoying hop that we all hate.
Both good.
