IMCO Hydraulic Steering overflowing at reservoir
I recently bought a new to me 2005 ‘27 Ultra Shadow and I am working through some bugs. The boat has a 525 with IMCO dual hydraulic steering to the helm.
I dropped it in the water a few days ago and the hydraulic steering was stiff and difficult to operate.
I topped off the reservoir, bled the system by cycling the steering wheel lock to lock for at least 10 minutes.
This seemed to do the trick. The boat ran great and steering felt normal.
Fast forward a few days, I just noticed that the power steering fluid is now backflowing and overflowing through the reservoir cap. Essentially, the system is draining itself through the reservoir cap.
There are no signs of leakage at the rams, hoses, fittings, or PS cooler.
Any idea what would cause the system to “backflush” or push excessive fluid back into the reservoir causing it to overflow ?
Side note- I’ve done my due diligence and searched through the forums, but found no helpful info for my specific problem.
I filled reservoir and slowly worked the steering wheel from lock to lock, holding it at each lock for a second or two.
I made sure to keep the reservoir from running low, and cycled the steering wheel until no more air bubbles were present.
I ended up using one and a half bottles of fluid. And I now have about that much that has overflowed.
The boat has an XR drive.
ill have to try to bleed the rams at the outside rear of the boat.
I just don’t understand why the system would burp out about 40+oz of fluid a few days after running it.
I thought these systems were self bleeding? I have never had an issue. I disconnected my hoses this past summer to do some maintenance, retightened hoses, full left, full right a couple times. All good. My reservoir is at least 12" above pump and rams.
