Merc Racing 800sc rear mount starters & stuff >
Old 01-06-2020 | 08:07 PM
Strip Poker 388's Avatar
Rob
Default Merc Racing 800sc rear mount starters & stuff
These are the rear mount style starters,I get these with some other stuff, im not sure they work.
$25 a pc plus shipping
im not on here as much, so might b slow to respond to post or pm's
Rob601948sofa
alt w/ new case,not sure if works $40
ignition 20.
pick ups, pair 150.
depthfinder sender, 20.00
Stellings water hoses 800sc, new 25.00 set
Stellings water hose elbow, 25.00 set
1
1
Strip Poker 388 is offline
Old 01-06-2020 | 08:16 PM
Rob
shouthco door latch, both 10.
vent window screens, 1 the rubber needs pushing back in, 40.00
crower cam button, 5.00
Dom 3 circuit gaskets,35.00 the hole pack
whipple tensioner 2 for 50.00
Whipple bypas valves, good, 50. for both
Original Merc Speedmaster 5 outdrive sticker kit, all in pick 75.00
Rob
Old 01-07-2020 | 07:27 PM
B38
Dimensions of white latches.
thanks
B38 is offline
Old 01-07-2020 | 09:05 PM
JBA
I am interested int he hatch screens.
JBA is offline
Old 01-07-2020 | 10:50 PM
Rob
thanks
they are the same as my thread in the hustler section updating,ill have to measure, guessing its a standard size, as pik one is cracked
Old 01-07-2020 | 11:13 PM
Rob
k, make sure ya see that the rubber insert needs pushing back in, these are original on the hustler, bomar, prob a standard size,i was gona keep them,but not camping on boat anymore,sux used it less than 10 hours this year on fresh rebuilt BMax's.
Im getting burnt out on throwing money at it.
hi tide 16k boat lift gearboxs,used, have pick of guts, worm drive etc
Old 01-07-2020 | 11:27 PM
Rob
areo, a1000, this was my spare i used it as a backup, but now a transfer pump filling boat up on the pier, it pumps, but i would not run it on a motor,rebuild able, make offer, automotive i think 175 to rebuild, with all new guts
Whipple 500efi 3.3 pulleys.I bought new compressors and boost went up past 10, was at 8ish, the new whipples where a lot better/tighter than my old ones, had buy new pulleys slow it down, was at 883hp with old pulley,
i alos have some bigger pulleys
I will trade for some 30ish ptich 4 blades,bravo ones,in 30 and 32, trade plush cash, also could use some 5 blade 28ish props,
Old 01-07-2020 | 11:33 PM
Rob
Old 01-08-2020 | 07:06 AM
F-2 Speedy's Avatar
interested in the CMI jumper hoses and whipple pulleys, can you post pics of the pulleys ?
thanks
F-2 Speedy is offline
Old 01-08-2020 | 12:30 PM
Rob
BLAD has committed to the Stellings hoses
ill get some piks of actual pulleys
Rob
