Gentry twin turbo kit 6500$
GENTRY TWIN TURBO KIT 6500$ OBO
I have this listed in the classified area with pics.
All the parts in the turbo kit are new and unused with original boxes.All aluminum parts are hard anodized for corrosion resistance. Ready for paint or powdercoat . All nuts, bolts, washers fittings, hoses, hose clams are included. Copper/Nickle intercooler with 3-stage sea pump, billet crank, JE pistons, Heads and more see list. This kit will make 750 hp on pump gas when put on stock 454. With good heads and 500 ci will be around 900 on pump gas more on race gas. Other parts included are listed below. Crank and sea pump are used and in excellent condition see pics and list. Please let me if you have any questions.
PARTS LIST Turbo kit to many parts to list see pics 2 garret turbos with water cooled exhaust housings
Billet Kryptonite crank 3.92 stroke standard rods and mains knife edged (used) New set of JE dished pistons extra HD Precision components pins not the stock je ones Stefs Aluminum oil pan Anodized and polished. Never run was used on a show motor New Crower Solid roller lifters with axle/roller pressure fed oiling New Crower rev kit New Pro Topline cast iron heads 320cc intake ports raised exhaust ports. Same as RHS heads before they were made in china these are the original ones from New Zealand good stuff . Heads have some surface rust from sitting see pics. 3 stage KE sea pump Needs impellers no corrosion (used) Pulley not included Imco valve covers (used) Mercury Dual cooler belhousing no corrosion has small crack at dowel pin hole definitely reparable see pics. I have more pics just ask if you need to see others.
6500$OBO
6500$OBO
