350 Mag MPI
Old 01-24-2020 | 11:07 PM
fastlane40's Avatar
Default 350 Mag MPI
Just got a 350 Mag serial number OW002492.
There is no wiring to the distributor.Looks like it should take a plug,maybe 3 wire.
fastlane40 is offline
Old 01-24-2020 | 11:55 PM
BUP
early version did not use it... its the cam sensor and not used because the fuel injectors were batch fired -- BUT later versions DID PLUG into the cam sensor as it was USED ----- to end up firing the fuel injectors in semi batch fired.
All this goes by engine serial number when it was NOT used and when it WAS used. I would have to run your serial number when I get a chance to if it was or not used.
Very specific info that is not in the service manuals either nor out there.
BUP is offline
Old 01-25-2020 | 01:47 AM
fastlane40's Avatar
Thanks for reply.I looked everywhere.
Must be not needed.
Old 01-25-2020 | 04:12 PM
BUP
the correct answer is no plug into the HVS period... That's because you have the early version set up and earlier ecm 555 calibration, Persay the lessor EC requirements to be met for the EPA standards here in the USA for that build timeframe..
BUP is offline
