496 Stroker build for Scarab SCS >
Old 01-31-2020 | 10:13 AM
Default 496 Stroker build for Scarab SCS
Found an engine builder / machine shop that builds 496 strokers to sell.
​​​​​​Going to request a roller cam. Is there a certain marine cam that everyone goes for with these motors?
Also, I believe the scat crank that he uses is Cast. Will that be ok or should it be forged?
And one last thing. With 9.8-1 compression Im guessing 93 octane will be a requirement. If I was to fill up with 89 at the lake and use octane booster would it be ok?
Here's the build list in the ad;
496 Chevrolet big block stroker
540hp / 600tq
9.8-1 compression
Forged pistons
Long H-beam rods
Scat crankshaft
All new internals
New harmonic balancer
New HD flexplate
Stainless roller rockers
HD pushrods
Comp valvesprings
Block is line-honed, parralell decked, bored and plateau honed.
Cast iron heads , pocket ported
2.250 intake and 1.88 exhaust valves.
Engine does not include intake and valve covers.
SCARAB.23.SCS is offline
Old 01-31-2020 | 02:32 PM
I've seen cast scat cranks break on the first dyno run,for a endurance engine such as marine usage, callies compstar at minimum, marine engines never get a break from loads such as a car at cruise
Ironhorse dave is offline
Old 02-12-2020 | 12:32 PM
Spend the extra on forged since this is a new build but I've also ran stock GM cast cranks extremely hard but on 454/485 hp builds with any issues. Much less power though.
getrdunn is offline
Old 02-12-2020 | 12:36 PM
What max rpm you plan to run? Also I would try and stay under 9.4:1 with cast iron heads.
getrdunn is offline
Old 02-12-2020 | 09:17 PM
Good to know about the compression!
going to order the forged crank .
The cam I was looking at is the comp 11-456-8. But I just learned about "reversion" so I need to look into that some more and maybe go more mild.
Old 02-13-2020 | 03:10 PM
Cam threads are very common and opinions very but if you want a cam that's been proven over and over and works well in any 489-516 CI you might want to consider the crane 741 cam. It's an old grind but works well with GM rec port heads and aftermarket. Just a thought for you where you don't have to worry about whether it's going to work or not. It simply will and easy on valvetrain along with reaching your goals easily.
getrdunn is offline
Old 02-15-2020 | 10:43 AM
I never heard what exhaust you plan on using. Make all difference in the world when picking a cam. Build sheet has flex plate, you better use a flywheel 🙀
1BIGJIM is offline
Old 02-15-2020 | 10:50 AM
I was going to pull my stock mercruiser exhaust off and see how it looks but I would like to get a stainless marine or EMI thunder exhaust. And yeB flywheel! That was just the guys ad I copied, he builds motors for boats or cars.
