Speedo Problems Solved >
Old 11-07-2002 | 11:28 AM
Dock Holiday's Avatar
Charter Member #34
Default Speedo Problems Solved
I have had problems since I got the 36 with the speedo. First we could not get the hoses at the outdrives to stay connected. Finnally solved that problem, then I get into Florida waters and have clogged up the tubes twice.
Problem Solved
I just ordered a new Gaffrig GPS Monster speedo.
The GPS kit was a little expensive, so I plan to wire it into the output of my Ray GPS chartplotter.
I think ALL boat builders should be installing this. Have talked with guys that own them, and it is the only way to go.
Dock Holiday is offline
Old 11-07-2002 | 11:48 AM
CigDaze's Avatar
Sure makes life a little easier, doesn't it?...
...Now remember, when traveling in a current...Uhhh, never mind!
Just messin' with ya, Mark! Cool purchase!
CigDaze is offline
Old 11-07-2002 | 12:25 PM
thisistank's Avatar
Hey, I think my speedo's clogged too. Is there a way you can blow anything out of it?? Do you just disconnect the line from the back of the speedo and stick an air hose in there?? Is it a biotch or what??
Tank
thisistank is online now
Old 11-07-2002 | 12:34 PM
Charter Member #34
Tank
Tank,
Yes, that is the procedure. Take the hose off the back and blow compressed air through it. The first time for me it worked just fine. But the second time, I have not been able to get it cleared. A real pain in the A$$.
Daze,
I have mumbled a few choice words for you brother!!!
I sure have the fever to head back your way. The wife wants to go to the Keys for the races, it will just be a bad time for me to get away from the office. Are you going down there?
Old 11-07-2002 | 12:53 PM
CigDaze's Avatar
Tank,
What dock said...
First I usually just see if I can dislodge whatever's in there with a coat hanger or some sililar device...Then it's compressed air from the front back(Meaning from the speedo).
Mark,
How's it goin' up there?
Ya, we're going down to Key West for the races. It should be a great time. November in Key West...Ahh, perfect. I know what the office thing can be like...I got lucky this year again.
CigDaze is offline
Old 11-07-2002 | 01:08 PM
thisistank's Avatar
Thanks you guys, I'll check it out. I'm still trying to get the numbers with the new motor I put in.
Old 11-07-2002 | 01:35 PM
CigDaze's Avatar
Dude, that's gotta be killin' you if you don't have a working speedo...I've followed your saga. Good luck!
One more thing. Whatever you do, don't try to clean it with a drill. It will break off in there and then you'll really be pissed!
[I have no first-hand experience with this...No, really. I mean it]
CigDaze is offline
Old 11-07-2002 | 01:57 PM
Default Unclogging speedo
I've always unhooked the hose where it goes into the outdrive and blown the obstruction out from there. A lot easier than taking the dash off. Just depends on where the trash is.
jmeng is offline
Old 11-07-2002 | 03:00 PM
Charter Member #34
Default Re: Unclogging speedo
Both times on mine the outdrive tube has been clear. It has already worked up into the hose. You bring up a good point though. You should try that first and it could save you some time.
Old 11-07-2002 | 03:16 PM
Interesting, I wouldn't have thought that the trash would make it that far up the tube. Every time I've had to do it I could usually feel the trash near the pickup. Guess it gets pushed up the tube further when your running 70+
jmeng is offline
