Webster stud girdles with Keith Eckerd 2pc valve covers >
Old 02-29-2020 | 09:23 AM
Nbn
Default Webster stud girdles with Keith Eckerd 2pc valve covers
Can I make the Keith Eckard two piece valve covers work with Webster stud girdles and have enough clearance with the three-quarter or 1 inch valve cover spacers does anybody have any experience with it? Motors are
world block low decks and world heads
cmi etop exhaust with roller rockers
looking to add space for Webster girdle
doable ?
Nbn is offline
Old 03-01-2020 | 11:12 AM
what cam do you have,,most likely girdle will not fit.will need a space w/ the KE spacer.
sutphen 30 is offline
Old 03-01-2020 | 03:55 PM
Nbn
Not sure what cam is used, but the motors are
555ci blown with 875hp dyno
they just tried fitting the girdle for valve cover clearance
Instead the Webster’s designed shape extends
to far in the way of the quick release wing bolts
looking at the pictures of the Howard cams girdle any one know if they could clear
wing bolts and spaced up to fit? 3/4 to 1 inch
maybe?
Nbn is offline
Old 03-07-2020 | 10:56 PM
Nbn
Could not space the KE valve covers up to fit
girdles ,headers Interfered with the 2 piece covers
went with the Teague Marine angle cut covers
to be able to top off my Mechanical roller valve train with peace of mind having the Webster girdles, Holding it together
2 sets of 2 piece valve covers will be going up for sale !
Nbn is offline
Old 03-07-2020 | 11:30 PM
with oilers or without? Price? I’m piecing together my next winter builds lol.
tmmii is offline
Old 03-08-2020 | 09:19 PM
Nbn
Oilers. No
2 complete sets with breathers $375
Nbn is offline
Old 03-09-2020 | 07:03 AM
Oilers. No
consider them sold. Sending pm now.
tmmii is offline
Old 03-09-2020 | 10:26 AM
why are you going to a stud girdle???
added strength in rocker system, i would guess.
i almost wish i had set up on my motors. get tired of adjusting rockers.
but , my engine builder doesn't like them , said dont need running only 5500--5700 rpm.
flashgordon is offline
Old 03-09-2020 | 10:45 AM
F-2 Speedy's Avatar
the more aggressive the valve train and spring pressures it will flex the rocker studs, that's why some go to shaft rockers, I run the websters also, good choice
F-2 Speedy is offline
Old 03-09-2020 | 11:16 AM
what are webster???
rock shaft system?
or its a stud girdle system....
i had jomars on my super gas car...
again i was going to put stud girdle on my motors, and engine builder said , i dont need and stud girdle are tuff on aluminum heads
my isky cams are 714 lift,,,dont know spring pressure.
