Intercooler placement >
Old 03-12-2020 | 11:27 AM
phughes69's Avatar
Default Intercooler placement
I am doing a blow thru twin turbo system on my Scarab 300 this time. I am going to use the Holley Sniper throttle body system because it has pretty good support. I want to use this type of intercooler
but not sure where to mount it. This is similar to my engine compartment layout
. The battery is almost directly in front of the engine and the trim pumps are located outboard of the battery. I have thought about mounting it above the thermostat housing, but concerned about how to mount it.
For plumbing, I am using a merc transom mount water pickup to feed water to the intercooler. How have others that have used a intercooler mounted it and how to you feed water to it?
phughes69 is offline
Old 03-12-2020 | 08:41 PM
I fed the intercooler water from a T on the water inlet of the oil cooler which was fed by a stock merc seawater pump picking up from the drive...
This was a Procharger intercooler..
My NEXT one would've been from Frozen Boost But I sold the boat (put it back stock)
Boatally Insane is offline
Old 03-12-2020 | 09:31 PM
I think you are going to have to mount the inter- coolers a little further away than the thermostat housing to keep from having a lot of sharp bends , I was having the same problems so I ended up making my own inter- coolers , just make sure your inter-coolers are big enough so you don't have a restriction . I have a 2 stage water pump that I use to feed the engine and inter-cooler
green lightning is offline
Old 03-13-2020 | 07:49 AM
I mounted my inter-coolers on top of my carburetors
Old 03-13-2020 | 09:01 AM
phughes69's Avatar
Do you have any better pictures of the intercoolers? What cores did you use?
Old 03-13-2020 | 09:25 AM
I got the cores from bell intercoolers
Old 03-13-2020 | 09:27 AM
when i was mocking them up
Old 03-13-2020 | 09:29 AM
then i machined them flat
Old 03-13-2020 | 11:27 AM
If you have the height, green lightning has the right idea. I have seen that Vortech lid with inlets on both sides so your twin turbo plumbing could be very short and straight. Elbows are bad...
tomcat is offline
Old 03-13-2020 | 11:37 AM
Tom, I never got a chance to thank you for all the help guess you were busy with the v-16 project the inter-coolers came out nice and work real well .
thanks Alan
