Is this screwed washerusefull on bravo? >
Old 03-13-2020 | 06:33 AM
jeff32's Avatar
Default Is this screwed washerusefull on bravo?
What are these for exactly?
i know when i will unscrew it the bolt will break...
need to have it or can live without?
jeff32 is offline
Old 03-13-2020 | 07:01 AM
Its used to help keep the drive grounded. Used in conjunction with a Mercathode
Do you plug into shore power?
AllDodge is offline
Old 03-13-2020 | 07:52 AM
jeff32's Avatar
most of the time on trailer at home yes
10 -12 times a year when boat is in the water overnight and i sleep in it
other wise it never left in water
so...???
jeff32 is offline
Old 03-13-2020 | 08:18 AM
Figuring you've had the boat for a while and do regular maintenance. During maintenance have you ever found parts of the drive being eaten away, if not then your doing fine
Do you have a Mercathode installed?
If so then its doing its job, if not then guess your still doing ok
This is what can happen to a drive given enough time and galvanic corrosion
AllDodge is offline
Old 03-13-2020 | 09:31 AM
jeff32's Avatar
jeff32 is offline
Old 03-13-2020 | 10:17 AM
Dude, keep mercathode working, its a painfully simple system. Especially if you ever run in salt water. I think it makes a difference even in overnight stays.
Keith Atlanta is offline
Old 03-14-2020 | 06:50 AM
Official Name : Continunity Washer. The screw thread is 10-34, if you want to drill it out and re-tap.
fletchersmachine is offline
Old 03-14-2020 | 06:54 AM
Default Opps, My Bad ...10-24.... too early no coffee
Oups…. My Bad …….10-24... No coffee yet !!!!!
Old 03-14-2020 | 08:26 AM
jeff32's Avatar
thanks for that info will need it for sure!
jeff32 is offline
