502 MPI Tune >
502 MPI Tune
502 MPI Tune
Old 03-24-2020 | 12:00 AM
Default 502 MPI Tune
Just Wondering If Anyone Had Sent Their ECU Off In The Mail To Be Tuned, And Had A Decent Running Boat Afterwards. I Know I Prop Dyno Would Be The Real Way To Go But Id Probably Have To Drive 10 Plus Hrs To Find A Shop Capable Of Doing So. I Am Not Looking To Squeeze Every Last Bit Of Power Out of My Setup , I Just Dont Want It To Run Lean And Damage Anything.Boat Already Had A Procharger And I Dont Think PO Did Any Kind Of Tuning I Added A 168731 Cam ( 500Efi Cam ) And Cmi Exhaust Might Have To Go .030 Over After I Measure Bores
28EliminatorDave is offline
Old 03-24-2020 | 06:28 AM
really need to tune it on the water,,prochargers and vortech's are kinda of a pita to tune.you should get o2 bungs put into your pipes.
sutphen 30 is offline
Old 03-24-2020 | 12:04 PM
Why would just not have it tuned on a dyno???
and why does every word start with a capitol letter in all of your posts??
Griff is offline
Old 03-24-2020 | 12:16 PM
It does jump off the page doesn't it ?
+1 on the dyno
speicher lane is offline
Old 03-24-2020 | 12:19 PM
I Suppose , I Am Doing All Of My Own Work Guess I Was Just Trying To Do As Much Myself As I Could.
Would Tuning On An Engine Dyno And Actual In Boat On Water Be The Same As Far As Load And Mapping ?
Its A Habit I Cant Really Break, It Comes From Years Service Writing Work Orders, For Some Reason The Company At The Time Thought It Looked More Professional....
Old 03-24-2020 | 12:22 PM
Come on now, service writers use ALL CAPS! Lol!
Diamond Dave is online now
Old 03-24-2020 | 12:36 PM
FWIW, a friend sent his ECU to Alexi at Boostpower and had it programmed. According to him boat runs top notch. Call him and discuss it and see what his thoughts are maybe.
cheech is offline
Old 03-24-2020 | 12:45 PM
articfriends's Avatar
Tuning on a dyno gets it close under controlled conditions, tuning it on water gets it dead on. I usually do both. Ive done mail order tunes for guys where weve swapped ecus back and forth in mail, programmed off their tailpipe numbers, afr readings via text etc with good success. A procharged motor, that would be a little more difficult as it usually involves quite alot of changes when doing on water or dyno
articfriends is offline
Old 03-24-2020 | 08:31 PM
I think with all the money I'm investing in my engine I will just have to suck it up and take it to someone that can tune it on the water for best results. There is not much for performance Marine where I'm located
Can bungs be added to the jacketed section of exhaust to where they will stay dry? I will try searching more on that subject
Btw that was extremely difficult not doing the caps typing, took about 3 times as long lol
Old 03-25-2020 | 10:19 PM
Yes, you can have an O2 bung welded into CMI's.
Engine dyno will get you very close, especially if they run your headers and engine accessories.
Griff is offline
