700 hp motor 540 BBC >
Old 03-25-2020 | 09:11 PM
Default 700 hp motor 540 BBC
$11200.00
700hp
540 ci Dart Big M Block
42 hours
runs great just pulled from boat this fall
forged Crankshaft
H Beam rods
forged pistons
ARP hardware
aluminum C&C heads
roller cam
roller billet rockers
roller lifters
aluminum intake
950 CFM carberator
10 quart offshore racing oil pan
new raw water pump
serpentene belt system
Donskihp is offline
Old 03-25-2020 | 09:25 PM
What exuast were you running that cleared those valve covers?
freekazoid is offline
Old 03-25-2020 | 09:53 PM
Proof of hours? Built by who? Dyno sheets?
Baja226sport is offline
Old 03-26-2020 | 07:45 AM
I don’t know who made my exhaust, there 5” diameter
Donskihp is offline
Old 03-26-2020 | 07:52 AM
I purchased boat from Performance Boat Center last summer, no info on engine builder or dyno sheet. There add listed hp at 700 And hours at 40. All I had to go on was Brads good faith and honesty
Donskihp is offline
Old 03-26-2020 | 01:12 PM
He was running different valve covers looking at the pics....marine aluminum valve covers...now they are chrome stamped steel...those wont work with marine exhaust I dont think.
kreed is offline
Old 03-26-2020 | 03:03 PM
Smile
Good catch. Now see if you can read the numbers on the exhaust side. I thought I would be able to tell what kind they were by exhaust port but I can't.
getrdunn is offline
Old 03-26-2020 | 07:18 PM
Looks like a bunch of Chiquita's lol
Old 03-29-2020 | 10:14 AM
The side of head string looks like it starts with PC. Could these be pro comp heads?
ACrooks69 is offline
Old 03-29-2020 | 01:36 PM
X2. Also OP would be very helpful if you posted a little more about the engine and history. I realize you trusted brad at performance boat center however the words like (roller, billet, forged, CNC, H beam, etc are pretty much meaningless. Example if brad (seller) told you the heads are "C&C" he should certainly know the manufacturer. Or maybe not considering C&C. I'd suggest doing a little investigating and identify exactly what you have the best you can. You selling this for new build? If so what were your speeds and rpm on the water were you getting. There's got to be a build sheet or builders name somewhere. Don't get me wrong the engine looks great but it smells a tad bit like "perfume on a pig".
Identify some parts. Did you do a compression test and or leakdown?
getrdunn is offline
