Go Back  Offshoreonly.com > Technical > Electronics
Fuel pump relay question >
Old 04-10-2020 | 12:57 PM
Default Fuel pump relay question
2000 Baja gen6 502. Aeromotive A750 external pump.
I am not getting power to my fuel pump. My relay is getting 12v but the pump wire is 0 voltage. I should here the pump turn on when the key is turned to acc? Thank for help.
zerolash is offline
Old 04-10-2020 | 01:01 PM
F-2 Speedy's Avatar
EFI ?? there should be a connector with a gray ? cap on it on the rear of the engine, pull the cap and you should see 3 fuses, one it for the fuel pump if this is a stock wiring harness
F-2 Speedy is online now
Old 04-10-2020 | 01:04 PM
Yes it’s EFI. I check all 3 fuses and all are 12v.
Stock harness.
zerolash is offline
Old 04-10-2020 | 01:52 PM
From what you've described it sounds like the fuel pump relay itself is bad or there is a break in the wire running from the relay to the pump. The relay's aren't that expensive. It might be worthwhile to get one. If the problem is elsewhere you'd have a spare. You could check out the wire connection using an ohm meter and a length of wire.
70open28 is offline
Old 04-10-2020 | 01:55 PM
I think it’s a wire I have a new relay I tried.
thanks man
zerolash is offline
Old 04-10-2020 | 07:06 PM
No problem. Good luck.
70open28 is offline
