Bilge LED's
Old 04-11-2020 | 07:37 AM
F-2 Speedy's Avatar
Default Bilge LED's
Im thinking of installing some in the engine compartment, what do you guys suggest, color, brand, looking for ease of installation, switched power from the dash is in place.
TIA
F-2 Speedy is offline
Old 04-11-2020 | 10:37 AM
buck183's Avatar
Following.
buck183 is offline
Old 04-11-2020 | 11:23 AM
I think alot are using the strip LEDs with controller to change colors
Drock78 is offline
Old 04-12-2020 | 08:15 AM
F-2 Speedy's Avatar
Geeez, no help, must of put this in the wrong place, 130 hits and no links
Old 04-12-2020 | 09:26 AM
https://www.superbrightleds.com/ They have multiple applications for mounting on a smooth surface with 3M backing and another application for mounting on rougher surfaces Part Number: WFLB-CW96
kjm5125 is offline
Old 04-12-2020 | 06:23 PM
here you go
https://www.dhgate.com/wholesale/sea...=#hpsearch1806
sutphen 30 is offline
Old 04-13-2020 | 10:04 PM
TomZ's Avatar
I used strips in tubes from Super Bright if I recall correctly. Everything was plug and play with a controller at the helm. It lights the bulge and the cockpit. Multiple colors, audio sensitive, etc.
TomZ is offline
Old 04-14-2020 | 03:24 AM
F2-Speedy:
Here you go. Super cool. Easy to install. Idiot proof. Bullet proof. I paid $150 in 2007.
https://www.crutchfield.com/S-fMt9we...ercar-Kit.html
I'm sure other companies have similar kits. Streetglow's website says NEW kits are coming.
You may find a NOS Streetglow kit on the web.
dbkski is offline
Old 04-22-2020 | 08:35 PM
Strips from Superbright Led's here. Ditched the OE incandescent housings on each side of the bilge and used their wiring for the led's. OE switch already in place on the dash. Did the same in the gunnel pockets.
Please don't make me post pics here.
Tractionless is offline
Old 04-23-2020 | 10:40 AM
I put these in. They work great and put out a lot of light and look pretty good as well. Post #235
Phil'R Up 2001 Baja 25 Outlaw
iaoutlaw is offline
