BBC 565 Blower ready long blocks
565 Blower motors, long block assemblies
Bowtie tall decks 565 CID, O-ringed with ultra copper head gaskets, pin oilers in blocks, nodular caps, ARP main and head studs, 4340 4.500" cranks and 4340 I beam 6.535 rods with ARP2000 bolts, JE blower pistons, Total Seal stainless gapless rings, King Racing rod/main bearings, Brodix 360s 2.300/1.900 Manley severe duty stainless int/Inconel exh valves, Pac springs, Jesel shaft rockers and belt drives, solid roller cams, Crower pressure fed tappets, ProRod heavy wall pushrods, Canton marine pans, mellings blueprinted NV high pressure pumps, complete long block assemblies less intake manifolds, ... call for further details Al 905 252 0592
$11,500 USD each
each
$11,500 USD each
each
all the right parts here to make some good jam with the appropriate blower setup... we running 1471 high helix retrofits on a 4" setback with 1150 dominators @6% under these make more grunt than the 10s ever did, I've priced to sell as I have a new combination I want to build for my cat, shorter stroke, bigger bore yadayada.. need to run in a much higher rpm band for cat...
these were happy in the 5500 RPM zone...
to the top!!!
