Restore candidate
Old 04-12-2020 | 10:29 PM
Default Restore candidate
I have this 1986 Sleekcraft enforcer that I got cheap because somebody had not paid their inside store fees for a couple years. It was a lien sale.
It is 28 feet and has twin 330hp 454's with 1.32 gear ratio alpha's.
If the boat seems worth while to restore, my plan was to sell the 454's and put a couple of nice 383's with aluminum heads and aluminum exhaust to lighten the load.
I have never done fiberglass work or restored a boat.
I am committed to replacing the transom if needed and am willing to also replace the parts that the engines mount to if they are soft and I think they are. I am not willing to cut the floor out and replace stringers up towards the front of the boat. If it needs that, I'll part it out and then buck it up with a saw and take it to the dump.
I would like to pull some wood out of a few places with a hole saw to see what I have and would like to start with the stringers because if they are bad, I am not going to go any further. I was just going to pull out like a 1 inch core and then replace with with a dowel and epoxy.
My question is, are thevertical boards that make up the sides of the ski locker in the floor the stringers? They do not line up with the fiberglass covered wood that the engines mount to.
Thanks,
Russ
highplainsdrifter is offline
Old 04-13-2020 | 02:50 AM
Not worth it. Clean it up and run it as is. Or part it out for $$, and find an old cig, fountain, formula, hustler, sutphen or velocity to restore.
hogie roll is offline
Old 04-13-2020 | 08:41 AM
scarabman's Avatar
On the question about ski locker sides being stringers, there is no way to tell without getting a look under the floor. Stringers on opposite sides of bulkheads/separate compartments do not necessarily line up with each other down the length of the boat. Engine compartment stringers very often are different from the rest of the boat to accommodate engine mounting.
scarabman is offline
Old 04-13-2020 | 08:44 AM
F-2 Speedy's Avatar
Get that corona out of the boat........
F-2 Speedy is offline
Old 04-13-2020 | 09:00 AM
rak rua's Avatar
Well spotted ^^^
rak rua is offline
Old 04-13-2020 | 02:34 PM
Yeah, I do think about that. I am only in this thing for a couple grand, but I know these boats aren't really valuable even in nice shape.
Thanks for the input.
Old 04-13-2020 | 06:18 PM
Rookie's Avatar
Get it running, clean it up and enjoy it. Definitely do no do the engine swap. Small blocks would be going backwards.
Rookie is offline
Old 04-13-2020 | 06:50 PM
I have a friend who has one, with a couple of built NA 454s and -2 shorties... 90+ mph boat and handles good.
phragle is offline
Old 04-17-2020 | 04:19 PM
Too Stroked's Avatar
Alpha drives behind big blocks are a hand grenade with the pin pulled. They were a horrible combination that was (thankfully) only offered for one year. I'd pass.
Too Stroked is offline
Old 04-17-2020 | 08:11 PM
My initial post stated I was planning on switching to small blocks.......FYI
