Rpm droop  flashing on/off on diacom 7.4 mpi >
Old 04-16-2020 | 03:20 PM
evaluex's Avatar
Default Rpm droop flashing on/off on diacom 7.4 mpi
7.4 MPI (310 hp)
NO fault codes stored on the ECU
but when running on idle speed
diacom screen (right side page) flashes/varies on the line "RPM DROOP" ON & OFF all the time
when engine running faster (+1000 rpm) "RPM DROOP" stays on OFF
why @ idle ?
What does rpm droop means?
How to solve this issue?
evaluex is offline
Old 04-16-2020 | 04:14 PM
Your idle is falling below preset minimum. Not knowing a serial number or year it is probably 600, so its falling below
Look at the IAC and what are the counts and is it steady?
AllDodge is offline
Old 04-20-2020 | 05:25 AM
evaluex's Avatar
I ordered new IAC and let you know
thx for the help/info
evaluex is offline
Old 04-22-2020 | 08:29 PM
Have you checked base timing against what your repair manual says it should be?
Tractionless is offline
