1st gen 525 efi digital trim >
Old 04-25-2020 | 11:58 AM
Default 1st gen 525 efi digital trim
Does anyone have a diagram or wire colors for early 525 digital trim connections? I know there used to be tags on the wires on the harness but they have fallen off over the years.
Unlimited jd is offline
Old 04-27-2020 | 07:36 AM
Just in case someone else needs this info in the future. I’ll be interested in what all is needed to make this project happen Jaimie. Keep me in the loop
endeavor1 is offline
Old 04-27-2020 | 08:26 AM
I will be working on it tomorrow. I have an extra sender I can plug in and try before routing the wires to my forward engine harness. Hoping it works. I want to go to an all glass dash
Old 04-27-2020 | 08:41 AM
This isn't from a 525 but may help
AllDodge is offline
Old 04-27-2020 | 08:48 AM
If your going from digital to analog then it needs a converter. I installed one on mine and it never has worked, and gave up trying to fix it. It could be my new old stock converter may have been the issue, don't know but I'm also a single motor so not that big a dealAnalog to Digital converter
The old part 845060A1 is the old kit which is no longer sold. The new part is 884359T1 which is the same as the old part but does not have the screws and spacers.
Page 1083 at boatinfo on Manual 39
Boatinfo - Mercruiser Service Manual nr. 39 - 2006-Up Bravo Drives
AllDodge is offline
Old 04-27-2020 | 03:44 PM
525 has smartcraft and digital already in the harness. The picture endeavor1 posted is the correct plug.
Old 04-28-2020 | 06:48 PM
Installed (2) new 3 wire sensors, plugged into that connector endeavor1 posted a picture of and we have digital trim on the smartcraft display.
