1998 502 update options. What would you do?
Hello guys. Bought a new to me 1998 Cobalt 252 with a 502 and Bravo 1..
Engine shows 297 hours, but is 22 years old.and I want to make sure I don't have issues with it this season.
I am planning on upgrading the engine for next year. Not enough time to do this season, but will be looking to achieve a naturally aspirated 500 HP and 65 MPH. I already have the Hardin Marine Seaward exhaust from my previous boat. (bought this because I didn't plan on buying a bigger boat, and the previous engine was only a 7.4L, so the Seaward was a perfect fit. And still is for this season. Not so sure with the planned upgrade next year because they claim it's good up to 415 HP)
The boat does have captain's call exhaust, but I am seriously considering eliminating it and blocking off the opening when the engine comes out. I like the sound, performance and better cam options with a longer exhaust riser.
Knowing that I will be getting a new cam, lifters, push rods, rockers, etc.. next year, I don't want to buy anything unnecessarily..
So, what would you do?
option #1- Get the stock injectors sonic cleaned and flowed. Install an adjustable fuel pressure regulator and the better Gen IV flame arrestor. Cost around $600+
option #2- Eliminate the Merc EFI and go carb. Cost around $1000+
option #3- Eliminate the Merc EFI and go with the Holly sniper. Cost around $1200+
My only concern right now, would be if I go option #3 that I need to install O2 sensor bungs to run it this season.
Season is approaching fast and I need to act soon. Thanks for any help you guys can provide.
It's a new to me boat, so I don't have much to go off of. Preventative maintenance.is key for this year. Cables, Impeller, thermostat, plugs, cap, rotor, wires, filters, hoses, fuel system. You get the idea
0L017470 should be MEFI 1. Does have cool fuel. What did you change to get 500 HP?
If I could get $10k for my stock 502, I'd be all over that. Does seem like a great deal for the price.
1 vote option #1. Thank you
Being a MEFI 1 should be able to obtain same power or even more, just depends on how far you want to go. I wanted mine to be able to run on 89 octane so this can limit overall power
Go the easy route. Simply clean and flow test the injectors, basic service, fluids/filters/oils/lube etc and run it. I would not bother with a new fuel pressure regulator. Less than 300 hours on the motor is not that much. I'd run it as "old reliable" and have fun with it.
have injectors flowed and cleaned, call it good . I see injectors that flow low from these 20+ year old motors when I do them and hear/ see horror story's of melted pistons , lost seasons, etc. Smitty
