Go Back  Offshoreonly.com > Technical > Electronics
Fuel pump no power >
Fuel pump no power
Fuel pump no power
Old 04-26-2020 | 01:56 PM
Default Fuel pump no power
Baja 232 w a 502 mag mpi.
I am getting 1.4 volts to pump. It’s not turning on. When I turn the key I don’t hear the beep along with pump turning on. I just put 2 brand new harnesses in it this weekend. My pump relay has 12v and the grey wire only has 1.4 I would think it would be much higher. Pump turns on if I hook it straight to 12v. Also not sure what these wires are for. I didn’t have them on my old harness.
zerolash is offline
Old 04-26-2020 | 03:05 PM
Motor serial number?
AllDodge is offline
Old 04-26-2020 | 03:32 PM
502 Mag MPI HJ 1996–2001, 6HJ
zerolash is offline
Old 04-26-2020 | 04:03 PM
F-2 Speedy's Avatar
is there a grey cap on a plug with 3 fuses inside one is for the fuel pump ? if this an OE wiring harness
F-2 Speedy is offline
Old 04-26-2020 | 04:48 PM
Yes grey plug has a cap
zerolash is offline
Old 04-26-2020 | 05:04 PM
1996 to 2001 goes across 2 manuals, not a lot of help
The single wire Blue/Tan (if it is tan) would be for transmission over temp (you don't have)
2 prong connectors
Unknown because unable to find anything in diagrams using those colors at rear of motor
Note fuses 15, 16 and 17
The fuel pump has a ground and Gray going to power up when relay energizes.
Ignition ON, supplies power to MPR. The MPR contact gets power from the engine circuit breaker thru a fuse and Red wire. The MPR is energized via the engine harness to EFI harness thru a pink wire
MPR supplies power to ECM and fuel pump relay contact. FPR is energized by the ECM thru the Green/White wire
Since your not getting a beep, then the beeper may not be connected and/or your not getting power to the ECM
AllDodge is offline
Old 04-26-2020 | 05:21 PM
Wires are the same but would probably have all 3 fuses under one cap 13
AllDodge is offline
Old 04-26-2020 | 06:40 PM
Has all three fuses under box. Relay is getting 12v through pink wire. Grey wire is only getting 1.4v. What is MPR?
zerolash is offline
Old 04-26-2020 | 06:45 PM
Main Power Relay
speicher lane is offline
Old 04-26-2020 | 07:58 PM
How do I check that?
zerolash is offline
