Bravo xr vs Bravo one propshaft >
Old 04-28-2020 | 10:29 PM
Default Bravo xr vs Bravo one propshaft
I have a bravo one and the propshaft is twisted pretty bad, I acquired a labbed 29 hydro QIV that has a welded in 1 1/4" hub I was wondering if a bravo xr 1 1/4 propshaft will go directly in the bravo one or do you have to buy the whole prop shaft kit? If so what are the differences are the splines inside the lowers different or the same? Just trying to save a few $$$
Taylor4.8 is offline
Old 04-28-2020 | 11:29 PM
I believe you just need the 1 1/4 shaft and the bearing carrier . I think the lower gears are the same.
Revd Up is offline
Old 04-29-2020 | 06:28 AM
Mbam's Avatar
Offshoreonly Advertiser
Gears are the basically the same except the XR gear has a larger bore to fit the propshaft. Probably better to buy the kit then to bore the gear out.
Mbam is offline
Old 04-29-2020 | 07:31 AM
VoodooRob's Avatar
With this conversion kit, you use your current gears
https://www.cpperformance.com/p-1573...rsion-kit.aspx
VoodooRob is offline
