Hydromotive P5X hub kit >
Old 05-08-2020 | 10:19 AM
PFL
Default Hydromotive P5X hub kit
Hi!
What hub kit does the Hydromotive P5X use? Drive is obviously bravo 1. I tried to change my Bravo 1 prop to hydro but it did not tighten up, the bravo hub kit was a bit too long.
PFL is offline
Old 05-08-2020 | 03:58 PM
There is a shorter piece that goes in the hub. I went from bravo to p5x and had to get one I will see if I can find the part #.
Bama is offline
Old 05-08-2020 | 04:22 PM
You need a 3-5/8" drive sleeve, part # 850821Q12
Bama is offline
Old 05-08-2020 | 06:06 PM
PFL
Great, thank you ! 😀
PFL is offline
Old 05-08-2020 | 07:54 PM
Hydromotive is open I just dropped a prop off last week to have some nicks repaired. Give them a call, great guys and they will fix you up with what you need.
Padraig
Padraig is offline
Old 05-18-2020 | 10:16 AM
bbladesprops's Avatar
Offshoreonly Advertiser
We can help you.
Just give us a call.
Brett
[email protected]
bbladesprops is offline
Old 07-09-2020 | 03:29 PM
Have the same proplem with my p5x, and looking for the correct sleeve.
JaniH is online now
Old 07-09-2020 | 04:48 PM
Call BBlades or Hydromotive.
Padraig
Padraig is offline
