454 Mag-carb on a bravo 1 upgrade advice. >
Old 05-09-2020 | 01:28 PM
Question 454 Mag-carb on a bravo 1 upgrade advice.
The stock HP on my carbureted 454 MAG gen V(1992) is 360 hp. This motor has a total of 6 hrs on it. Thought about swapping the lower unit to a bravo III to be able to run a duo prop. Should give me better hole shot and slightly better fuel economy. I've changed my mind and now think I'm going to up the horse power instead. I have no idea though where to start. Reading/searching through posts it seems the consensus is to start with a cam and higher flowing carb. Current carb cfm is around 730-750 which should be plenty up to 500hp though. If this was a car I'd have no problem knowing where to start, but it's not. I need some help please. I realize the bravo I top end is rated at 500hp and at some point I would need to upgrade it. Better point out - where do I find upgrades like the exhaust, cam, etc...
Batmeat is offline
Old 05-09-2020 | 03:00 PM
525sc manifold, blower and carb.....
phragle is offline
Old 05-09-2020 | 03:03 PM
A carb changed is based on what is planned for the motor. Decide on how much HP you want, then the parts come from that
AllDodge is offline
Old 05-09-2020 | 04:24 PM
That's a little much for what I want. Looking to bump my power to ~450 max.
Batmeat is offline
Old 05-09-2020 | 05:02 PM
Found a link to an upgrade on this site, but can't post it till I have 10 posts...
Batmeat is offline
Old 05-09-2020 | 06:39 PM
Finally.....
upgrade 454 mag carb.
Sent a PM to Griff. I hope he is still around knowing that post is old.
Batmeat is offline
Old 05-10-2020 | 12:33 AM
Mods on a boat engine are a lot different than a car where you can feel small improvements. Boats need 50hp more to feel even a small difference and a 100hp to be anything worthwhile and at that point you really should start from the ground up.
Almost everyone here will tell you to find a “fun” engine and save your current engine in the garage. All of us have gone through this same process and have found that to be the best route.
Baja Rooster is offline
Old 05-10-2020 | 12:57 AM
Originally Posted by Batmeat
Finally.....
I'm still around once in a while
Somebody a long time ago actually replicated 90% of my build and it dyno'd at 420hp Paging Griff
Griff is offline
Old 05-10-2020 | 01:15 AM
BTW, you will need aftermarket exhaust with longer risers to prevent water reversion and maximize the upgrades. I was running Imco Powerflows.
Griff is offline
Old 05-10-2020 | 08:58 AM
Oh come one, your a filthy power hungry b!tch, you know you want it !!!!
phragle is offline
