Replacement steel braided Latham steering hose >
Old 05-11-2020 | 09:42 PM
Default Replacement steel braided Latham steering hose
I did a search and did not find a recent answer to replace a single steel braided hose. It looks like it got pinched against the swim platform. It ultimately failed in the middle (not at either fitting).
Who is making these with the right pressure and fittings?
Thanks,
Tom
F14A water jet is offline
Old 05-12-2020 | 07:19 AM
I’m sure there is a hydraulic repair shop near you that can get what you need Tom. I can’t tell from your picture but the hose “looks” like one of the Mayfair hoses that I got from Hardin. Good luck
ph1971 is offline
Old 05-12-2020 | 07:37 AM
Thanks for the input! I will pull the line today and look for marks/part #s/etc...
Are there newer, higher performance hoses that are more adapted for the Gulf's salt water environment? I would be interested in replacing all 4 lines if its an upgrade.
Old 05-12-2020 | 08:08 AM
Sydwayz's Avatar
Forum Regulator
Any local hydraulics shop can likely make that for you. Just take it off and carry it with you.
Sydwayz is offline
Old 05-12-2020 | 03:59 PM
Taking it to a local hydraulic shop may be your best bet..
Some steering manufactures use 45° flare fittings and some use 37° flare fittings.. Matching it up will assure you get the correct fittings on your hoses.
Boatally Insane is offline
Old 05-12-2020 | 09:05 PM
I got it done with stainless steel fittings...Pensacola Rubber and Gasket was GREAT to work with!
