353 with 500 EFIs - where does Lube reservoir mount >
Old 05-20-2020 | 06:02 PM
Default 353 with 500 EFIs - where does Lube reservoir mount
In the middle of a engine upgrade to 500's. Wondering where Formula is mounting lube reservoir? The 353's I see online are not on the engines, on the port side its near the blower. With all of the waste water plumbing and Latham, no free spot on the SB side that I can find.
Any one have pics?
snowrunner is offline
Old 05-25-2020 | 06:05 PM
Mine are mounted on the gunnels next to the motors. Starboard just after the Steering reservoir and the port just after the ground block
twin242ls is offline
Old 05-25-2020 | 07:02 PM
VoodooRob's Avatar
We had an 05 353 with 525s, the reservoirs were mounted on aluminum brackets bolted to the intake.
VoodooRob is offline
Old 05-26-2020 | 07:34 AM
Interesting, Hadn't seen the Intake mount. Curious how it attaches? Do they use the intake mounting bolts?
I have a bunch of plumbing on my SB side. The Vacuflush/Y valve and Latham are all using the space.
Old 05-26-2020 | 09:09 AM
That looks like a home made aluminum bracket
Unlimited jd is offline
Old 05-26-2020 | 09:33 AM
VoodooRob's Avatar
[QUOTE=Unlimited jd;4740741]That looks like a home made aluminum bracket[/QUOTE
I didn't make the brackets, and bought the boat from original owner who doesnt have that skill set by any means. He had a few custom things done during the build of the boat. Im sure that's not a factory production piece. Most likely a way to solve a request and get the boat delivered.
Old 05-26-2020 | 09:52 AM
Formula can be creative, especially with new packages. Are these early 525’s? They look like they have 500 efi style oil filter mounts, which was on the first set of 525 vins.
Old 05-26-2020 | 01:01 PM
VoodooRob's Avatar
Boat was an 05, I dug up the engine vins OM950334, OM950581. The boat had ITS with Sweptback XRs.
Old 05-27-2020 | 09:19 PM
Nice package!
The 525's were first gen. They had those funky front lift brackets that allowed that aluminum plate to mount up. The front brackt won't fit a 500, as I already learned the hard way (have one for sale...).
