502 rpm question
I have a new to me formula 400ss. I just got new props (bravo 3) running 4 blade 26p.
Motors are 502 mag mpi
Boat full of fuel (approx 200 gal) and only ran 4200rpm. Motors say 4600-5000.
One great thing is at 3000rpm I’m getting 30 mph, and even 3400 getting 34mph. A 1 to 1 all the way through really.
Now I love that I’m getting 30 at 3000 and most likely will just cruise and not hit 4000rpm and mostly 32-3500rpm. But will this ruin the motors?
I can drop to 24 and most likely be in the rpm range but most likely loose the mid. Any info is great.
Just my opinion here: your max rpm is down from 4800 to 4200. That’s significant to me and hard on the engine. This is all assuming engines are in good state of tune.
Sorry for confusion, but was boat manufactured with Bravo 1 drives running 3 blade 26, and now has Bravo3 drives with 26 pitch props?
Lots of Formula owners on here hopefully some has experience with same boat.
If memory serves the boat came with B3 26P. There are several on the Formula forum. I think your down on power, look at the plugs and see if there all the same color. If there is differences do compression test and fuel injector cleaning.
How many hours and does one motor achieve more rpm then the other?
curious if dropping to 24p 4blade will that be enough to bring the rpm back up to normal range and what will it do to my mid range.
Both motors put out same rpm too.
Are you reporting that your boat DID turn up correct rpm with 3B 26 props, and will only turn 4200 now with only the 4B prop change? Or are you saying you don't know what it was turning with the 3 blades? Just because two props are marked 26P, they don't necessarily present an identical load to the motors, especially on a boat with more than average prop slip.
Your bottom could be dirty, boat could be loaded more heavily than intended, motors could be down on power. Carbs could be not opening all the way up (cable adjustment), lots of things.
You really aren't giving us the bigger picture.
