Gear Oil Fitting Bellhousing Leak >
Old 05-22-2020 | 02:49 PM
Default Gear Oil Fitting Bellhousing Leak
Installing bravo one drive...button everything together. All went smooth. Notice oil leaking around seem from oil nipple. Cleaned up surfaces and lubed o-ring. Still leaking. Any thoughts. Not a fast leak.
what’s the sealing surface the red gasket or the o-ring? Or both?
1MOSES1 is offline
Old 05-22-2020 | 02:50 PM
Here is the o-ring mating surface
1MOSES1 is offline
Old 05-22-2020 | 03:24 PM
Panther's Avatar
Frank's Marine Service
I don't see a picture of the bell housing? Was the o-ring installed on the bellhousing prior to installing the drive? Did you use grease to hold the o-ring on or weatherstrip adhesive? I recommend adhesive.
Panther is offline
Old 05-22-2020 | 03:43 PM
Didn’t take a picture of the bellhousing...yes o-ring was installed. Just ran out to store to get a new one. When I pull it apart again I’ll take a picture. I use marine grease to tack it in place
1MOSES1 is offline
