Go Back  Offshoreonly.com > Owners Forum > Sunsation
1997 dominator prop >
1997 dominator prop
1997 dominator prop
Old 05-24-2020 | 06:45 PM
Default 1997 dominator prop
Hi
i just bought a 1997 dominator whitout step with fresh hp500, what prop should i run with this setup ?? I have a set of revolution 4 blades 25 pitch i think is à little low in pitch.
Perf langlais is offline
Old 05-25-2020 | 09:04 AM
Mentalpause's Avatar
When you say fresh HP500, I assume you mean twins? I think the factory put Bravo 1 4 blade 30s on twins. The Rev 4s are smaller in diameter than a B1s. My guess is you will be under propped. You can always call the factory and they will confirm what they suggest running. Pretty sure it won't be those Rev 4s.
Mentalpause is offline
