4 blade 26 pitch prop pair >
Old 05-31-2020 | 07:18 PM
Default 4 blade 26 pitch prop pair
Bent a prop over the weekend. Heard most companies turn around time to repair is long so I’d like to see what’s out there.
Anyone have a nice used set?
May be interested in a different pitch if someone has had good experience with them on a 32 fever stepped hull. I’m happy with what I have so I haven’t tried anything else.
Would buying 1 replacement be okay? Let me know if that’s a dumb suggestion.
Bent prop is HC-CL26L
1” prop shaft.
jtbooten is offline
Old 05-31-2020 | 08:24 PM
Had them on my 32 and then I switched to 27 Hydromotive 4 blades,The hydros were a better ,faster prop.
make sure you check the round out on the prop shaft
boatnt is offline
Old 05-31-2020 | 08:27 PM
Round out?
jtbooten is offline
Old 05-31-2020 | 08:42 PM
If that is a Hydromotive call them. I just had one repaired and it was a little under 2 weeks. Good Guys!
Padraig
Padraig is offline
Old 06-09-2020 | 12:51 PM
Called a bunch of places and Mark’s Props in IN has the quickest turn around. I mailed it last Tuesday to them. Spoke with them and it should be heading my way tomorrow. Not a bad price either.
jtbooten is offline
