Increase water pressure >
Old 06-01-2020 | 01:22 PM
F-2 Speedy's Avatar
Default Increase water pressure
I need to increase water pressure in the engine, running a 2 stage pump -16 to the engine, -12 in and out of the inter cooler dumping out the transom and 2 -4 rear intake dumps, is there a restrictor that can be inserted in the AN fitting to accomplish this, thought about restricting the primary side of the -12 fitting at the pump, thoughts ?
F-2 Speedy is offline
Old 06-01-2020 | 02:17 PM
What is the pressure now?
abones is offline
Old 06-01-2020 | 02:25 PM
F-2 Speedy's Avatar
about 5-7 lbs at cruise, maybe a little less
Old 06-02-2020 | 08:28 AM
F-2 Speedy's Avatar
Wheres all the experts ..........
Old 06-02-2020 | 09:00 AM
I have the opposite issue, if I don`t relieve the pressure it goes 20psi+
I`m running the intercoolers off a seperate pickup , just engine off the single stage pump.The intercooler should have at least 10psi.
Somewhere along the way you gotta reduce the diameter of the over board fittings , I have`t found any AN restrictors ..
How`s it idle with the water running thru the intercooler ?
Thanx all I got, sorry .
ICDEDPPL is offline
Old 06-02-2020 | 09:14 AM
F-2 Speedy's Avatar
Idle is good maybe a little fat, reducing the -12 dump will increase psi on the cooler and should increase all around psi, thanks
Old 06-02-2020 | 09:16 AM
What are you using for a pickup and inlet hose?
Unlimited jd is offline
Old 06-02-2020 | 09:23 AM
F-2 Speedy's Avatar
standard bravo through the drive, 1.25 hose to the pump,
Old 06-02-2020 | 09:48 AM
SB
Thinking out loud.....maybe put a 15psi (or 20 ?)regulator on intercooler outlet. Will stop water flow thru it idle/low speed and will open once motoring pretty good.when psi gets up to determined regulator psi you choose.
SB is offline
Old 06-02-2020 | 09:52 AM
SB
Just thought of something, never used one do I don’t know how reliable, but they make valves with an fittings. This way you can adjust restriction size with s push or pull.
SB is offline
